CCNA Exam resit
Apr 1st, 2007
I sat the CCNA exam and failed. I'm studying again to resit for the 2nd time. Where can I get the updated study materials? I dont want to fail again. Pls help.
mfreijser Tue, 04/03/2007 - 00:52
You can find loads of information @! Here are some examples:
Cisco Press, a place where you can buy Cisco books, including great books for the CCNA exam:
CCNA Prepcenter, a place where you can find lots of information about preparing yourself for the CCNA Exam:
Cisco Partner E-learning Connection (PEC), here you'll find a lot of labs and flash-enviroments with information about CCNA:
Hope that this will help you out! Please rate if the posts helps!
wopundo874308 Thu, 04/05/2007 - 09:02
Thanks for that was some kinda help but do u know where i can get the simulator????
mfreijser Fri, 04/06/2007 - 01:36
What kind of simulator are you looking for? A router-simulator or a simulated exam?
I must warn you that most simulators cost money, the free ones (if there are free ones left) are usualy not that good. By the way; finding simulators is quite easy:
rsfelling Mon, 04/16/2007 - 09:54
A friend of mine tells me that Boson DOT com has some good study stuff; however, I downloaded their demo and didn't like it.
Pass4sure DOT com also has some stuff.
