DHCP not giving IP's to wireless clients
Apr 1st, 2007
I am configuring an 877w router.
I have configured my DHCP pool, no problems. I tested it using my local LAn, all clients are getting the ip's from the pool I specified.
However, when I scan and try to connect to my SSID, it starts connecteing 'forever' and states a problem: my client can't get an IP lease from my DHCP server. When I give my Windows XP box an available ip from the same NAT pool, it connects to the network, but it can't ping my gateway (although its setup..). I also can't access any network recources. I can ping my loopback IP and my local setup IP.
I'm kind of, lost at the moment.
brispin Mon, 04/02/2007 - 05:46
Normally, this 169.x.x.x ip address is shown when the AP is not able to get an IP address from a DHCp server. So, check whether a DHCP server is available to provide Ip address and properly configured. Else, configure a static ip address to the AP.
Xintruder Mon, 04/02/2007 - 08:58
There you go mate
Octacis#sh running-config
Building configuration...
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Octacis
logging buffered 51200 debugging
logging console critical
enable secret -----
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
resource policy
clock timezone PCTime 4
ip subnet-zero
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address
ip dhcp pool sdm-pool1
import all
dns-server 212.x.x.59
ip tcp synwait-time 10
no ip bootp server
ip domain name alkhaldi.net
ip name-server 212.x.x.59
ip ssh time-out 60
ip ssh authentication-retries 2
crypto pki -- removed to make post less than 4000 characters-
username xxx privilege 15 secret xxx
bridge irb
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
pvc 8/35
pppoe-client dial-pool-number 1
broadcast-key vlan 1 change 45
encryption vlan 1 mode ciphers tkip
ssid Al-Jabri.net
vlan 5
ssid Alkhaldi.net
vlan 2
authentication open
infrastructure-ssid optional
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
station-role root
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2 native
ip address
no snmp trap link-status
no cdp enable
interface Vlan1
no ip address
bridge-group 1
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname p4789860
ppp chap password xxx
ppp pap sent-username - password 7 -
interface BVI1
description $ES_LAN$
ip address
ip nat inside
ip tcp adjust-mss 1412
ip classless
ip route Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit
dialer-list 1 protocol ip permit
no cdp run
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
bridge 1 protocol ieee
bridge 1 route ip
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
-removed lines to make post less than 4000 characters-
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
I'm not sure what you're trying to do here.
You're wired LAN is probably getting the addresses from network due to being in VLAN 1.
If you want the wireless to get addresses from the same pool, you would need to change the encapsulation on interface Dot11Radio0.2 to 'dot1q 1 native', and get rid of the ip address.
If you're wanting a seperate pool, you'll need to create the second dhcp pool, create vlan 2, and create bvi2. You'd want to put the ip address of on interface bvi2.
