bug?? wlc, acs, peap & machine auth and intel wireless proset
customer has a wireless solution consisting of a AIR-WLC4402-50-K9 with software 4.0.206.0, several AIR-LAP1131AG-E-K9 Access Points , Cisco ACS 4.0, Windows 2003 Active Directory and a Microsoft CA.
WLC & ACS are configured for PEAP(MS-CHAPv2) plus machine authentication on acs.
on wlan-clients (mostly centrino-notebooks) this security solution configured with windows configuration service works fine...host AND user (both!) must successfully authenticate themselves against acs to gain access.
but with intel wireless proset-software version 11.1 it's enough to successfully authenticate as host OR user (not both!). this looks like a bug and is a really heavy security hole.
any ideas?
mmellet Fri, 04/06/2007 - 06:21
Microsoft PEAP clients also initiate machine authentication whenever a user logs off. This prepares the network connection for the next user login. Microsoft PEAP clients may also initiate machine authentication when a user has selected to shutdown or restart the computer rather than just logging off. Refer URL
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/acs32/user02/d.htm#wp803832
ok...i think you don't understand my question. sorry, my english is not very good. :(
i have only a problem with the intel wlan-client ...not the ms-client! with the intel-client no user-authentication is required for gain access to the wlan. the log of acs is also very curious:
szenario: machine auth successful, user auth not successful (user not in ads-group)
intel client (the acs says "auth failed" but the client gain access):
03/04/2007,15:08:05,Authen failed,testuser,Default Group,(Default),External DB account restriction,,,%DOMAIN%\%USERNAME%,10.x.y.z,,%DOMAIN%\%USERNAME%,25,CISCO-PEAP,,WLC01,
here the same log-entry with the ms-client (acs says auth failed and the client gains NO access):
03/04/2007,15:14:00,Authen failed,testdomain\testuser,Default Group,(Default),External DB account restriction,,,testdomain\testuser,10.x.y.z,,,25,MS-PEAP,,WLC01,
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
