VPN Question
bradlesliect
Where in your VPN config do you enter your username and password? I have the config for the router but dont know where the username/ password for VPN goes.
royalblues
Level 10
Level 10
Brad,
It depends on the database which you will be referring to for authentication
The usernames need to be defined on the global configuration mode if you are planning to authenticate the users via the local router database.
These can also be directed to a TACACS server
HTH, rate if it does
Narayan
This is what my current config looks like
crypto isakmp policy 1
hash md5
authentication pre-share
group 2
crypto isakmp key adsldynvpn address PIX2 no-xauth
crypto isakmp key adsldynvpn address PIX1 no-xauth
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel toPIX1
set peer PIX1
set transform-set ESP-3DES-MD5
match address 100
crypto map SDM_CMAP_1 2 ipsec-isakmp
description Tunnel toPIX2
set peer PIX2
match address 103
....where would the username be?
Brad,
What you have is an IPSEC VPN. It would mostly be a site to site VPN.
All you require in this is the key which already exists in the Config.
username & passswords are not configured in these type of VPNS
Narayan
OK.....
I need to configure a client's ADSL router to make a VPN connection to their ISA server.
How would I do that?
