04-02-2007 02:44 AM - edited 03-05-2019 03:14 PM
HI!
I Need link regarding 4507R Including power(Power suply) calculation
10xs
Ali
Solved! Go to Solution.
04-02-2007 02:47 AM
Hi ALi,
Have a look at this link
http://tools.cisco.com/cpc/PFN.cpc
You need a CCO login for the same. From product option select 4500 and click next and from there you can select the supervisors and other details.
Ankur
04-02-2007 03:03 AM
Hi Ali,
In addition to Ankur's post, make sure that you select the redundant Sup's option under the redundant Sup option. If you need the calculation for POE on the switch, please include the correct module number on the slot and also select the exact product number like Ip phone/Wirless AP on the module to get the proper calculation done.
Make sure that you also include your future growth into the calculation. Sometimes taking the wrong device count for POE doesnt give you correct part number of the PS for future growth.
-amit singh
04-02-2007 03:09 AM
Hi ALi,
Also check this link for power supply troubleshooting
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/hw_doc/4500inst/05trblsh.htm#wp1015135
For 4507R specification
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/hw_doc/4500inst/0aspecs.htm#wp1007627
DC Power Requirements and Heat Dissipation Specifications
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/hw_doc/mod_inst/0aspecs.htm#wp1012809
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/hw_doc/mod_inst/0aspecs.htm#wp1012188
Ankur
*Pls rate all helpfull post
04-02-2007 02:47 AM
Hi ALi,
Ankur
04-02-2007 03:22 AM
Hi Ankur;How r you!
10xs a lot for ur great reply as well as for the great Link
10xs
04-02-2007 03:03 AM
Hi Ali,
-amit singh
04-02-2007 03:09 AM
Hi ALi,
Ankur
