Time Change
Apr 2nd, 2007
We have CME installed in germany which +1 hour to the GMT but we are not able to the timing in the phone properly, it is showing -2 hours to the germany time after the DST change.
clock timezone GMT 1
clock summer-time GMT recurring last Sun Mar 1:00 last Sun Oct 1:00
Early help would be highly appreciated
mchandak Mon, 04/02/2007 - 04:12
  • Gold, 750 points or more
Is the time being displayed on the router correct ?? If yes, then under telephony-services you need to enter the command "create cnf-files" and reset the phones
nakhtacool Mon, 04/02/2007 - 09:17
yes, it is showing the time correctly at the router, it is only phones which are not showing the time correctly even after the reboot.
mchandak Mon, 04/02/2007 - 12:47
did you try the command "create cnf-files" option. This should fix the issue on all the phones except for the Java based Phones which would need a firmware upgrade to the latest code available on CCO.
EDIT: Incase that does not work, can u attach the extract from show run should lists global CME config along with info about phone model(s) which still have an issue
