DCEF process is running at 75%
Apr 2nd, 2007
Can you advise if there is some way to determine why this particular CEF process on slot 2 is running at 75% while the rest appears to be around 30%?
Cairo#sho ip cef resource
Hardware resource allocation status summary
Green (Normal), Yellow (Caution) Red (Alarm)
Slot HW Resource Name Util Alert
2 E2_Rx_PLU 32 G
2 E2_Rx_TLU 75 Y
4 E3 Rx PLU 25 G
4 E3_Rx_TLU 28 G
5 E3 Rx PLU 25 G
5 E3_Rx_TLU 27 G
6 E3 Rx PLU 25 G
6 E3_Rx_TLU 28 G
9 E3 Rx PLU 25 G
9 E3_Rx_TLU 28 G
11 E3 Rx PLU 25 G
11 E3_Rx_TLU 28 G
I would like to increase the CEF alarm parameters to stop the logs on the router being filled with the CEF resource messages, but I am concerned that this process is running higher than the others.
The device is a GSR with IOS Version 12.0(26)S5a
cisco 12012/PRP (MPC7457) processor (revision 0x00) with 1048576K bytes of memory.
MPC7457 CPU at 1263Mhz, Rev 1.2, 512KB L2, 2048KB L3 Cache
Last reset from sw reset
2 Route Processor Cards
2 Clock Scheduler Cards
3 Switch Fabric Cards
4 OC48 POS controllers (4 POS).
3 Single Port Gigabit Ethernet/IEEE 802.3z controllers (3 GigabitEthernet).
1 Three Port Gigabit Ethernet/IEEE 802.3z controller (3 GigabitEthernet).
1 Four Port Gigabit Ethernet/IEEE 802.3z controller (4 GigabitEthernet).
2 Ethernet/IEEE 802.3 interface(s)
10 GigabitEthernet/IEEE 802.3 interface(s)
4 Packet over SONET network interface(s)
2043K bytes of non-volatile configuration memory.
250880K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 256K).
David White Mon, 04/02/2007 - 08:57
  • Cisco Employee,
Hi mayambanzumba,
I think you would have better luck posting this question to a different forum.
Sincerely,
David.
