NetFlow and Policy-based Routing
We have a longtime and annoying problem in using NetFlow with policy-based routing. Consider a situation when traffic arriving at the input router intfc is routed to loopback via PBR (route map -> set int loop 1). And we want to use that loopback to get flow data (int loop 1 - ip flow ingress/egress). The command applies but there is no output in "sh ip cache flow". If enabled on physical intfc, there is output. Anyway, traffic is routed correctly but "sh int loop 1" gives 0 bytes input, although "sh int loop 1 accounting" gives correct in/out figures. Can anyone tell what is wrong? Can we get flow statistics from loopback intfc by any means?
Thanks in advance.
bwilmoth Fri, 04/06/2007 - 08:54
Here's the sample configuration:
interface g0/0
ip policy route-map g0/0-s0/0/0
interface g0/1
ip policy route-map g0/1-s0/1/0
interface s0/0/0
ip policy route-map s0/0/0-g0/0
interface s0/1/0
ip policy route-map s0/1/0-g0/1
match ip address 100
set interface s0/0/0
match ip address 101
set interface s0/1/0
match ip address 102
set interface g0/0
match ip address 103
set interface g0/1
access-list 100 permit ip any any
access-list 101 permit ip any any
access-list 102 permit ip any any
access-list 103 permit ip any any
Alternative configuration option:
set ip next-hop x.x.x.x <-- ip address of the next-hop router
This URL should help you:
