04-02-2007 06:34 AM - edited 03-05-2019 03:14 PM
Very quick question.
Is there such a configuration (on the 2800 series) which allows both of the routed ports to be plugged into the same LAN and be represented as a single IP address ?
I thought this could be done via a "backup interface" command that specifies one as the backup for the other, on a physical level?
If this is not available then I will have to look at bridging the interfaces and creating a VLAN SVI
Solved! Go to Solution.
04-03-2007 08:42 AM
Hello Nathan,
I have tested and it works. Follow the below steps:
1- Shut down both interfaces
2- Set the IP addresses (Same Address)
3- issue the backup interface command on the primary interface
4- No shut the primary
5- No shut the secondary
6- Enjoy testing.
Below you can find a smaple config:
interface FastEthernet0
description DMZ Primary
backup interface FastEthernet1
ip address 192.168.2.1 255.255.255.0
ip access-group INBOUND in
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
crypto map IPSEC
end
Westport-1811#sh run int f1
Building configuration...
Current configuration : 171 bytes
description DMZ Backup
ip nat inside
Appreciate your rating,
ip inspect FW_OUT in
duplex auto
speed auto
04-02-2007 06:53 AM
Nathan
I am not clear whether it is supported to use backup interface on one ethernet pointing to another ethernet interface. Even if it is supported I am not sure that you want to use it. Backup interface depends on the primary interface going protocol down and there are lots of failure scenarios where the ethernet interface is not passing traffic but is still protocol up.
I believe that if you want to use one ethernet to back up another ethernet that you should not assign IP addresses to the ethernet interfaces, should configure bridging, put both ethernet interfaces into the same bridge group, configure Integrated Routing and Bridging, configure the BVI interface, and assign the IP address to the BVI.
Rick
04-02-2007 11:56 AM
I have tried this with a loopback and it works. You have to shut down both ethernet interfaces. Set the IP addresses and then issue the backup command on the backup interface.
After that bring up the primary interface first and then the backup interface.
Let me know how it goes,
04-02-2007 11:19 PM
Interesting, im not going to have a chance to give this a go today, do you have a config output from the working appliance?
04-03-2007 08:42 AM
Hello Nathan,
6- Enjoy testing.
ip nat inside
duplex auto
speed auto
crypto map IPSEC
end
ip nat inside
duplex auto
speed auto
04-03-2007 11:15 PM
Thanks for the assistance, I will give this a go :)
04-03-2007 11:26 PM
Just to note that what Mr.rburts said is correct, that is this interface won't be considered down until the protocol/interface goes down and usually Ethernet interface don't go down. Therefore, I don't know your target or even how are you going to provide the failover functionality.
However, I provided the solution hoping this would answer your question,
