Frame-relay Mapping?
imran_mcse
I have 3 routers connected via fram-relay cloud. I am facing a problem in connectivity because the Hub router is not mapping the spoke routers IP with relevant DLCI but spokes are mapping IP to relevant DLCI to HUB. Below is output of frame-relay map on routers.
R1:
R1#sh frame-relay map
Serial1/0.1 (up): point-to-point dlci, dlci 102(0x66,0x1860), broadcast
status defined, active
Serial1/0.2 (up): point-to-point dlci, dlci 103(0x67,0x1870), broadcast
R2:
Serial1/0 (up): ip 172.26.22.1 dlci 201(0xC9,0x3090), dynamic,
broadcast,, status defined, active
R3:
R3#sh frame-relay map
Serial1/0 (up): ip 172.26.23.1 dlci 301(0x12D,0x48D0), dynamic,
I tried mapping manually on HUB router but it shows this error message:
R1(config-subif)#frame-relay map ip 172.26.22.2 102 broadcast
FRAME-RELAY INTERFACE-DLCI command should be used on point-to-point interfaces
Please help me to resolve this issue.
12 Replies 12
Richard Burts
MUHAMMAD
It looks to me like the issue that you have got is that you are configuring Frame Relay on the spoke routers on the physial interface and it therefore is operating as multipoint. But you are configuring Frame Relay on the hub router as point to point subinterfaces. So you have a mismatch in operational characteristics.
I suggest that you reconfigure the spoke routers to use point to point subinterfaces. I believe that this will resolve your issue.
Rick
Rick
Please have a look on the below sh run sample of routers.
R1:
interface Serial1/0
no ip address
encapsulation frame-relay
serial restart-delay 0
interface Serial1/0.1 point-to-point
ip address 172.26.22.1 255.255.255.0
ip ospf priority 255
frame-relay interface-dlci 102
interface Serial1/0.2 point-to-point
ip address 172.26.23.1 255.255.255.0
frame-relay interface-dlci 103
R2:
interface Serial1/0
ip address 172.26.22.2 255.255.255.0
frame-relay interface-dlci 201
R3:
interface Serial1/0
ip address 172.26.23.2 255.255.255.0
frame-relay interface-dlci 301
My Dear same like above setup I am using in a real production network and it is working perfectly fine from years. Why not in this lab scenario. Please guide me if something is wrong.
MUHAMMAD
The config information that you posted clearly confirms what I had suggested that R1 is configuring the Frame Relay with point to point subinterfaces and R2 and R3 are configuring Frame Relay on the physical interface. Therefore R1 is operating as point to point whle R2 and R3 are operating as multipoint.
Cisco does not do inverse ARP (mapping DLCIs) on point to point subinterfaces and does do inverse ARP (mapping DLCIs) on multipoint interfaces. This is why R2 and R3 are mapping but R1 is not. I am not convinced that you do not have IP connectivity as your network is configured, but you do have inconsistency. I suggest that you configure R2 and R3 to use point to point subinterfaces.
I do not know what you have in a real production network and take your word that it is working perfectly fine. I am not convinced that your test network does not work. But it is inconsistent and I suggest that you change it. If your production network is also inconsistent then I suggest that you change it also.
Rick
Rick
On point-to-point (sub-)interfaces the router will send all packets to remote end. According to Cisco's Q&A (http://www.cisco.com/en/US/partner/tech/tk713/tk237/technologies_q_and_a_item09186a008009457a.shtml) FR InARP is on by default regardless of interface type (p2p or p2m), but apparently since for p2p you don't need mapping to get things working (router will send all packets out anyway) InARP is not used.
In your setup you should nevertheless be able to ping remote ends of p2p sub-interfaces.
But believe me the setup like above is working perfectly fine in an production environment with 20 spoke and one HUB router.
For my this above lab setup what do you suggest?
I believe your lab setup is working too (in terms of connectivity), doesn't it?
I have just configured test p2p sub-interfaces in my lab and they also do not show mapping (just like yours), but ping is working just fine. So your lab setup seems to behave perfectly normal.
But my friend my all routers are not able to ping each other. Even I have restarted all routers many times. What do you think about the rburts' replies. He said that your production network is inconsistent, what do you think about his reply . I don't know how it is as its working normal from years.
Then you have different issue, and not FR map. Check status of all PVC to start with. Also, is communication broken between hub and the spoke routers or between two spoke routers?
There is no communication break between any pear + PVCs are active.
MUHAMMAD
If you do not have it resolved yet then I will repeat the suggestion that I made before: configure the spoke routers as point to point subinterfaces. Try this and let us know if the behavior changes.
Rick
Rick
Yah dear Rick I did as you suggested, now its working fine. But actually I was looking for the answer that why the same scenario is working in production setup. Amazing.
MUHAMMAD
I am glad that my suggestion helped you to resolve the issue in your test environment. Without seeing more detail it is difficult to know why the production environment is working differently than your test environment. Several possible things might explain it:
- the Frame Relay in production might be provisioned slightly differently than what you have in your test environment.
- different versions of IOS might behave differently.
- there might be some small difference in configs.
Rick
Rick
