Adding a new switch
Apr 2nd, 2007
I have taken over a relatively simple network which has 2 cisco catalyst 2950 switches with 48 ports each. these are full and i need to add another switch to the network can i add a Cisco Catalyst 2950SX Switch with 24 ports? if so could someone please advise me on how to do this?
Thanks a lot for any help you give.
royalblues Mon, 04/02/2007 - 08:02
  • Green, 3000 points or more
Friend,
The most simple setup would be to connect the new switch to any one of the old 2950 switches through a cross cable.
If you are runing VTP, then a trunk can be created to pass on the VLAN information to this
Narayan
Jon Marshall Mon, 04/02/2007 - 08:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
If you are running VTP already then make sure you don't overwrite your vlan information when you install the new switch.
Best thing to do if you are using VTP is put the new switch into VTP transparent mode. Then connect it to your other switch, set the VTP domain name and set the mode to client.
It will then pick up the existing vlan information from your other switches.
Jon
