eToken and vpnclient on linux
Plutakhin
Hello! Does Cisco vpnclient for linux support eToken?
Not applicable
Using versions of the Aladdin Runtime Environment (RTE) on Windows NT and Windows 2000 can cause the following behavior. The login prompt that is posted by the Aladdin etoken when connecting the VPN Client can get hidden in the background. If this happens, the VPN connection can timeout and fail with the following event:
But what about linux? Can I use eToken+linux+vpnclient simultaneously?
