VTP BLK meaning
Apr 2nd, 2007
can anyone explain what this means: * LOOP
Gi3/15Desg BKN*3004128.143 P2p *LOOP_Inc
Pari Thiagasundaram Mon, 04/02/2007 - 14:11
Error Message: SPANTREE-2-LOOPGUARDBLOCK: No BPDUs were received on port [chars] in [chars] [dec]. Moved to loop-inconsistent state
Explanation: This message indicates that due to a unidirectional link failure, or failure of a bridge, BPDUs are not being received on the port. Loopguard has blocked the port to prevent loops.
Check the bridge connected to this port and test the link for any unidirectional failures. Sometimes excessive delay between BPDUs can trigger this event. If this is the case, no action is required because the port state is restored with the arrival of the next BPDU.
network_team Tue, 04/03/2007 - 00:09
It appears to move from one vlan to another do you think this could affect performance
