Cisco router--HP procurve duplex/speed issue
I have a cisco 3800 series router connected on the LAN side to an HP ProCurve 4000m switch. I can only get this connection to come 'up' at 10half (for speed/duplex) if I set both to auto, it negotiates to 10half. All other settings and the interface goes 'down' and will not come back up. I have tried new cables and other ports on the switch as well. Same issue. Any ideas?
Luke
Ahmede Mon, 04/02/2007 - 11:30
We have the same issue, and we end up be leaving it at 10/half.. Can not explain why..
obukev Mon, 04/02/2007 - 16:59
We are running a Cisco 3825 Router with the following configuration:
interface GigabitEthernet0/1
description $FW_INSIDE$$ETH-LAN$
ip address x.x.x.x 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
load-interval 30
duplex auto
speed auto
media-type rj45
negotiation auto
no mop enabled
... and the 4000m has the following setup:
Type: 10/100
Intrusion Alert: No
Enabled: Yes
Status: Up
Mode: 100FDx
Flow Ctrl: off
Bcast Limit: 0
.... hope this helps.
nyr.hakeem-habeeb Tue, 04/03/2007 - 00:52
you could try adjusting the carrier-delay time on the cisco box (under the interface config mode) after locking both end to say 100/Full.
Eg.
config t
interface g0/1
!Generally you want to raise the time
carrier-delay 4
Please rate if this helps.
HH
