Vlan on notepad
Answered Question
Pari Thiagasundaram Mon, 04/02/2007 - 09:36
  • Silver, 250 points or more
Rather, this should work:
vlan 10
name test
vlan 11
name best
Correct Answer
Pari Thiagasundaram Mon, 04/02/2007 - 09:43
You dont need to write ENTER.
vlan 10
name test
sundar.palaniappan Mon, 04/02/2007 - 09:52
  • Green, 3000 points or more
Ali,
What you have in your original posting should work. Here is the output from a 3550 switch.
SW1-3550#vlan database
% Warning: It is recommended to configure VLAN from config mode,
as VLAN database mode is being deprecated. Please consult user
documentation for configuring VTP/VLAN in config mode.
SW1-3550(vlan)#vlan 10 name test
VLAN 10 added:
SW1-3550(vlan)#vlan 11 name best
VLAN 11 modified:
SW1-3550(vlan)#exit
APPLY completed.
Exiting....
BTW, don't forget to type in exit to logout to save the config.
Sundar
