PIX 501 and Internet Access
My network is very simple, like this: A DSL Modem is connected to a Cisco PIX 501 firewall/router, and a computer is connected to this firewall.
Now this PIX 501 box has two interfaces: Inside ( and the netwroked PC ( The outside interface is set to DHCP to be dynamically assigned an IP by the ISP's DNS server (
My networked PC (running Windows XP) is configured with an static IP (, default Gateway ( which is the PIX 501), and the DNS IP ( which is the ISP's DNS Server).
But I can NOT access the internet. I can Ping (the inside interface) but not the outside (
What am I missing and what should I do?
situwayne Mon, 04/02/2007 - 10:36
hard to say without seeing your config. can you pls upload the cofig.
pstebner1 Mon, 04/02/2007 - 13:19
First off, the command is SH RUN.
Second, if you remove the PIX from the equation can you connect to the internet?
Anyway, please post the config.
