%C4K_REDUNDANCY-5-CONFIGSYNC
Apr 2nd, 2007
We are getting this message every hour, how can we stop it without affecting the switch (4507R) operation..
Apr 1 09:29:40: %C4K_REDUNDANCY-5-CONFIGSYNC: The calendar has been successfully synchronized to the standby supervisor
Apr 1 10:29:40: %C4K_REDUNDANCY-5-CONFIGSYNC: The calendar has been successfully synchronized to the standby supervisor
Apr 1 11:29:40: %C4K_REDUNDANCY-5-CONFIGSYNC: The calendar has been successfully synchronized to the standby supervisor
Apr 1 12:29:40: %C4K_REDUNDANCY-5-CONFIGSYNC: The calendar has been successfully synchronized to the standby supervisor
Apr 1 13:29:40: %C4K_REDUNDANCY-5-CONFIGSYNC: The calendar has been successfully synchronized to the standby supervisor
Apr 1 14:29:40: %C4K_REDUNDANCY-5-CONFIGSYNC: The calendar has been successfully synchronized to the standby supervisor
Thanks in advance..
Jon Marshall Mon, 04/02/2007 - 14:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
This message is level 5 in syslog ie. notifications. If you want to stop seeing it you can raise your logging level to warnings but be aware that you may miss other information you would like to see.
Attached is link to all 4500 redundancy syslog messages and their levels.
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_system_message_guide_chapter09186a00801d0f38.html#1371982
Jon
Ahmede Mon, 04/02/2007 - 15:52
Thanks for your response.. I think I intrested more in knowing why we are getting this message every hour and how we can stop rather than hiding it..
situwayne Mon, 04/02/2007 - 16:19
this is interesting. The calendar and VLAN database files are always synchronized when they change. you shouldn't be getting this if nothing is changed.
