Dial Plan 3845
Apr 2nd, 2007
Does anyone knows a good link about testing Dial plan, in a 3845 ISR, for PRI circuits. Or how to create some sort of expect script, or TCL scripting?
Thanks in advance for your help.
Paolo Bevilacqua Mon, 04/02/2007 - 10:39
Sorry, you you are confident with your configuration, no script to test would be necessary. What is worring you ?
kelvin.blair Mon, 04/02/2007 - 10:53
I'm not sure exactly what you're looking for, but if you are looking for the ability to test the PRI, try using the command at the gateway "csim start #". This will allow you dial directly from the router, but keep in mind you will need a dialpeer to match what you are trying to dial for testing.
