Server Based MTP on non Cisco Hardware?
Apr 2nd, 2007
I've read that you can have a software based MTP on a "NT Server." Is this a supported configuration on non-Cisco hardware? If so, what is the best way to install it?
Thanks!
mchandak Tue, 04/03/2007 - 01:48
MTP Would only work with CM installed on the box . You cannot run S/W based MTP without installing CallManager on the server.
