CSM connection limit per second
Apr 2nd, 2007
Is there any way we can set the connection limit per second for a vserver or a real server on CSM?
Syed Iftekhar Ahmed Mon, 04/02/2007 - 16:36
CSM can only limit the number of connections to a server (using "max conns" under real).
Connection rate limiting is not supported by the CSM, but you can leverage the Cat6k QoS support.You can configure QOS on Cat 6k to limit traffic before it reaches CSM.
Syed Iftekhar Ahmed
