Site to Site with split tunnel issue
Answered Question
I can not get spilt tunnel to work on my production router
config:
int serial 0/0/0
desc external
ip add x.x.x.x x.x.x.x.x
ip nat outside
ip virtual-reassembly
crypto map ipsec-map
int fast 0/0
desc internal
ip add y.y.y.y y.y.y.y
ip nat inside
ip nat source inside list 101 interface serial 0/0/0 overload
Nat acl
access-list 101 deny ip 192.168.2.0 0.0.0.255 10.10.10.0 0.0.255.255 log
access-list 101 permit ip 192.168.2.0 0.0.0.255 any log
crypto map acl
access-list 102 permit ip 192.168.2.0 0.0.0.255 10.10.0.0 0.0.255.255 log
I can only get one or the other to work but not together.
Your thoughts are much appreciated. I have read about the order of operations with NAT, but still not dice.
Steve
Correct Answer by andrewnewell about 9 years 11 months ago
Hi Steve,
I have had a similar problem and got around it by using a nat pool and route map...this enabled me to to split tunnel. Firstly take out your line ip nat source inside list 101 interface serial 0/0/0 overload then add the following.
ip nat pool 'name of pool' 'ip ext from' 'ip ext to(can be the same as ip ext to' netmask 255.255.255.252
ip nat inside source route-map nonat pool 'name of pool' overload
route-map nonat permit 10
match ip address 101
hope it works for you
thanks
Andrew
Overall Rating: 5 (1 ratings)
Kamal Malhotra Fri, 04/06/2007 - 09:44
  • Cisco Employee,
Hi Steve,
what do you mean by split-tunnel? It looks like a L2L tunnel.
Please confirm.
Correct Answer
andrewnewell Fri, 04/06/2007 - 18:23
Hi Steve,
thanks
Andrew
Hi Andrew,
My boss added the route-map statement after reading and troubleshototing.
Although I was able to get this working in the lab enviromnet with the "ip nat inside source list " but in producation it didn't. not sure if it had soemthing to do with fast ethernet interfaces or serial interfaces, I don't think so.
at any rate you would have hit the nail on the head had this not been resolved prior to thursday.
Thanks all for responding.
Steve
