PIX 501 and internet access issue
My network is very simple, like this: A DSL Modem is connected to a Cisco PIX 501 firewall/router, and a computer is connected to this firewall.
Now this PIX 501 box has two interfaces: Inside ( and the netwroked PC ( The outside interface is set to DHCP to be dynamically assigned an IP by the ISP's DNS server (
My networked PC (running Windows XP) is configured with an static IP (, default Gateway ( which is the PIX 501), and the DNS IP ( which is the ISP's DNS Server).
But I can NOT access the internet. I can Ping (the inside interface) but not the outside (
What am I missing and what should I do?
Please note:
I attached a file which shows the current PIX config. Please refer to the attachment below.
Overall Rating: 3 (1 ratings)
Fernando_Meza Mon, 04/02/2007 - 23:00
Hi .. the config seems Ok .. but I believe you are doing doble NATing.
1.- As packets go from inside to outside (PIX)
2.- As packest go from PIX and out of the Modem.
I suggest you to try configuring your modem in bridge mode and the PIX as PPPoE client.
Here is an example you could use as reference.
I hope it helps .. please rate if it does !!
