DCD Directory Slow
Apr 2nd, 2007
My DC Directory is really slow no matter which phone model I am using to access it. My dcdsrvr directory is 145MB in size. While troubleshooting I found the following link :
Please check DCD Instability section. My CCM is 4.1(2). Is this document relevant to my problem?? Thanks in advance.
rob.huffman Tue, 04/03/2007 - 05:14
Hi Sheeraz,
I do think this is relevant, but you must use the procedure listed in the proper CCM 4.1.2 doc (not from the link you sent);
Pay special attention to this step;
1. Download DCDScripts.1-0-5.exe from the Cisco CallManager Version 3.2 ( registered customers only) website.
***Note*** This step is applicable only if you are running Cisco CallManager version 3.1(1) to version 3.3(2c). For Cisco CallManager 3.3(3) and later, a modified version of these scripts is installed along with Cisco CallManager. Thus, for Cisco CallManager 3.3(3) and later, do not download these scripts from CCO; instead proceed to the next installation step.
2. Copy and run DCDScripts.1-0-5.exe on all the nodes in the Cisco CallManager cluster and on the CRA/CRS application servers. Accept the default settings when prompted to do so and click Unzip.
Here is the Guide for CCM 4.1.2
Hope this helps!
