XOT Log Message
Apr 3rd, 2007
Does any one know what this log message could indicate (it must be new in IOS 12.4(12):
Invalid decrement of XOT in-use VC count 0
It apears right after the following messages:
[192.168.0.1,3674/172.16.0.1,1998]: XOT I P/Inactive
Clear (5) 8 lci 1
Cause 0, Diag 255 (DTE originated/Unknown
diagnostic)
[192.168.0.1,3674/172.16.0.1,1998]: XOT O P7 Clear
Confirm (3) 8 lci 1
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Tue, 04/03/2007 - 00:48
  • Hall of Fame,
    Founding Member
Doesn't seem malign. You had 0 VC's, a clear comes in, (for which VC I'm not sure), that isn't possible, so the message.
Hope this helps, if so please rate post!
e.hoehn Wed, 04/04/2007 - 23:01
At the time, this message occours, there are actvie VCs and these messages are printed very frequently. Any other idea ?
Paolo Bevilacqua Thu, 04/05/2007 - 01:40
  • Hall of Fame,
    Founding Member
Then is a cosmetic bug and you should open a case with the TAC.
