Understanding ASA AIP-10 Module
Apr 3rd, 2007
Hi There
I've got some questions about the ASA AIP Module:
- Is the traffic travelling through the AIP Ethernet port to the ASA, or is it an internal circuit ?
- Can you check the AIP module if it is operating ok ?
- Is there a step-by-step manual to set up basic functions of the AIP module ?
Thank you for the answers.
owillins Mon, 04/09/2007 - 05:44
I think that traffic travels through the AIP ethernet port to the ASA. For chacking of the AIP module Cisco works can be used or you can use link https:// to monitor the AIP.
Following links may help you
Managing the AIP SSM and CSC SSM:
Configuring the Cisco Intrusion Prevention System Sensor Using the Command Line Interface 5.1:
Installing AIP-SSM:
Installing and Using Cisco Intrusion Prevention System Device Manager 5.1:
