Root Bridge+Clients with Non-Root Bridge+Clients Howto?
Hi, i have two 1242AG access points. I would like to setup a bridge between the two to bridge ethernet lan segments, furthermore i would like to be able to connect wireless clients to either of the access points so i can get maximum range.
I did what i thought was correct, created the first access point a 'root bridge with wireless clients', and assigned the ssid.
I set the second access point to 'non-root bridge with wireless clients' amd set the same ssid as the first access point.
I cant even get the root bridge to work, i turn it on, it brings the radio interface up but i cannot connect with my wireless clients, infact i cannot even see the SSID!
Do i need to 'Set Single Guest Mode SSID' for the radios? What does that command do?
Any ideas? A link to config example would be much apreciated.
Chris
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
