configure cookis insert
Answered Question
Apr 3rd, 2007
Could anyone advice me how do:
- "configure to use active cookie persistence (cookie insert)"
- "configure to insert the cookis "xxx" into header"
my current configure is
service server1
ip address 10.1.1.10
protocol tcp
port 80
keepalive type tcp
keepalive port 80
active
service server2
ip address 10.1.1.20
protocol tcp
port 80
keepalive type tcp
keepalive port 80
active
content service
vip address 10.2.2.211
port 80
protocol tcp
add service server1
add service server2
balance leastconn
active
Any comments will be appreciated
Thanks in advance
Correct Answer by Gilles Dufour about 10 years 3 months ago
yes, that is enough to have persistence based on cookie
Overall Rating: 5 (3 ratings)
Gilles Dufour Tue, 04/03/2007 - 04:17
  • Cisco Employee,
All you need is to add this to your content-rule
url "/*"
advanced-balance arrowpoint-cookie
arrowpoint-cookie name xxx
Some research on those commands will give you more info.
Gilles.
julxu Tue, 04/10/2007 - 15:56
Thanks Gilles,
the actually the header I need insert is:
WL-Proxy-SSL: true
the arrowpoint-cookie name can not insert this.
Do I have to add something?
Gilles Dufour Tue, 04/10/2007 - 23:23
  • Cisco Employee,
this is not a cookie that you are trying to insert but a fixed header line.
This can be done for ssl traffic decrypted by the CSS [therefore you need the ssl module].
Here is a link to the command that you need :
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_guide_chapter09186a0080579f6b.html#wp1009981
Again this function is only available to SSL traffic when terminating the ssl connection on the SSL module.
Gilles.
julxu Wed, 04/11/2007 - 00:11
Thanks to clear this.
at this time, I have been only asked to setup http, no https, so, I will not insert this header.
However, is the rest configuration enough to setup the cookie persistence?
url "/*"
Please advice
Correct Answer
Gilles Dufour Wed, 04/11/2007 - 00:29
  • Cisco Employee,
