OSPF summary-address
Apr 3rd, 2007
Why does the following not work?
router ospf 1
redistribute connected
summary-address 0.0.0.0 0.0.0.0
I expect OSPF to distribute a default route but instead OSPF stops announcing any routes!
Any ideas?
Harold Ritter Tue, 04/03/2007 - 06:23
  • Cisco Employee,
The only mean to inject the default route in an OSPF autonomous system is through the use of the command "default-information" originate.
Hope this helps,
sundar.palaniappan Tue, 04/03/2007 - 06:38
  • Green, 3000 points or more
Dave,
The 'summary-address' command is used in ASBR, router connecting to an external AS, and I am guessing this router may be connected to your ISP.
If that's the case then just like Harold stated configure 'default-information originate' under your OSPF process and the router would continue to inject a default route as long as it has a default route in it's routing table.
Sundar
davegibelli Tue, 04/03/2007 - 07:10
Sundar
With bgp you will not get a default route from a peer so there is no default route in your routing table in the first place.
I want to summarise all bgp routes into a default route and only inject this default into ospf if the bgp session is up...
davegibelli Tue, 04/03/2007 - 07:25
Sundar
I have two bgp routers, each has a single peering session. I want each bgp router to annouce a default route into ospf but only if the bgp session is up.
Sounds simple but I cannot figure out how!
