CSM Help
Apr 3rd, 2007
I need help with an interesting request I need to configure on my CSM.
There are 3 total servers, each server holds information for 10 different users -- a total of 30 users. I need to configure a single virutal IP address so when a user clicks on http://virtualip it will re-direct them to their appropriate server via username. The only way I can re-direct them is by a local SQL DB Username which is passed in the packet.
How can I configure the CSM to look into the packet and re-direct the requests by username to their appropriate server. Is this possible?
Thanks in advance,
Gilles Dufour Wed, 04/04/2007 - 01:00
if the info is inside the HTTP header, you can create a header-map to match the name and associate the header-map with a server.
network_dude Wed, 04/04/2007 - 04:29
Thank you for your response...I was thinking the same thing, but I didn't think that kind of information was contained in the header. Would that be an application thing, do you think programmers could pass that information in the headers?
Gilles Dufour Wed, 04/04/2007 - 06:28
yes, they could pass it in the header as a cookie value or inside the url as a parameter.
