L2TP VPN on a Pix 506e
Apr 3rd, 2007
I've been trying to configure an L2TP VPN for our company remote employees to use VPN in hotels around the world as the Cisco VPN ports are often blocked.
I've used Cisco's own L2TP examples, and examples from various forums. All have the same response: The external PC gets an ARP reply from the PIX but nothing else when trying to connect. (Our 2nd PIX using Cisco VPN works fine)
Below is the important bits of the running config. Can anyone tell me the (probably obvious) thing I have missed or done to stop it working.
----PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
no fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
no fixup protocol sqlnet 1521
fixup protocol tftp 69
name 10.4.0.0 l2tppool
access-list l2tp permit udp host 217.x.x.91 any eq 1701
access-list nonat permit ip l2tppool 255.255.0.0 any
logging console debugging
ip address outside 217.x.x.91 255.255.255.192
ip address inside 10.0.0.10 255.224.0.0
ip audit info action alarm
ip audit attack action alarm
ip local pool l2tp 10.4.1.51-10.4.1.99
nat (inside) 0 access-list nonat
route outside 0.0.0.0 0.0.0.x.x.123.91 1
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server RADIUS (inside) host 10.0.0.8 awdth8^. timeout 5
aaa-server LOCAL protocol local
snmp-server community public
floodguard enable
sysopt connection tcpmss 0
sysopt connection permit-ipsec
sysopt connection permit-l2tp
crypto ipsec transform-set l2tp esp-des esp-md5-hmac
crypto ipsec transform-set l2tp mode transport
crypto ipsec security-association lifetime seconds 3600
crypto dynamic-map dyna 20 match address l2tp
crypto dynamic-map dyna 20 set transform-set l2tp
crypto map mymap 10 ipsec-isakmp dynamic dyna
crypto map mymap client authentication RADIUS
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp policy 20 authentication rsa-sig
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 1
isakmp policy 20 lifetime 86400
ca identity beattock 10.0.0.3:/certsrv/mscep/mscep.dll
ca configure beattock ra 1 20 crloptional
vpdn group l2tpipsec accept dialin l2tp
vpdn group l2tpipsec ppp authentication chap
vpdn group l2tpipsec ppp authentication mschap
vpdn group l2tpipsec client configuration address local l2tp
vpdn group l2tpipsec client configuration dns 10.0.0.3 10.0.0.8
vpdn group l2tpipsec client configuration wins 10.0.0.8
vpdn group l2tpipsec client authentication aaa RADIUS
vpdn group l2tpipsec client accounting RADIUS
vpdn group l2tpipsec l2tp tunnel hello 60
vpdn enable outside
ggilbert Tue, 04/03/2007 - 18:53
  • Cisco Employee,
Take this command out
Let me know if that works out.
Cheers
Gilbert
ggilbert Tue, 04/03/2007 - 18:55
  • Cisco Employee,
this should be
access-list nonat per ip mask l2tppool 255.255.0.0
