Time problem and CME-Locale files for CME 4.0(0)
Apr 3rd, 2007
I have an issue in my London Office.
After the Daylight savings time the phones still display wintertime.
Time on 2801 with CME 4.0(0) is correct ( uses NTP ) time zone is correct
But still the 7941 phones refuse to use this time.
My guess is now that this is due to the fact that i do not use the correct locale ( or better no locale file at all)
So i try to find the UK en Locale files for CME 4.0(0) but am only able to download the CME 4.0(2) and 4.0(3) locale files.
2 Questions :
Can the time problem be the result of having no locale file on my TFTP server.
And where can i find the locale files for CME 4.0(0), or can i use the newer files as well ?
Problem is I am not onsite as i am located in the Netherlands. So i want to be sure that what i change is correct.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Tue, 04/03/2007 - 07:10
Yes you can use the 'earlier' files. These are nothing more that strings in java files for localization.
I'm not sure it has to do with the localization, I would check which firmware are you running on the phones as well.
rob.huffman Tue, 04/03/2007 - 07:15
Hi Maikel,
I think the problem with the Java based phones like the 7941 is that they require a firmware upgrade. Here is an excerpt from the Field Notice for CME;
Customers who are using the following Cisco Unified IP phone models:
are required to upgrade to the following phone firmware to display the correct time:
* CCME 3.X, 4.0 and 4.0(x) customers need to upgrade the phone load to 8.0(4)SR2.
* CCME 4.1 and 7931 customers need to upgrade the phone load to 8.2(1).
From this CME Field notice for DST;
Hope this helps!
cco_heerema Tue, 04/03/2007 - 07:20
Ok thanks .. i think this will be the case to ..
will give it a go tomorow.
Thanks !
