unexpected traffic available to sniffer on a switch
Apr 3rd, 2007
I work on a 6000 seat network where unfortunately most seats have been placed in VLAN 1 - over 2000.
Occaisionally I will etherreal a switch port and see traffic between 2 hosts which we shouldn't see in a switched network.
I am assuming that the switch has blown its L2 forwarding table and has become a hub.
Is there a command which would tell me whether this was the case?
sh mac-address-table count seems to suggest that the switch still has plenty of room left :-
Total Mac Address Space Available: 7926
Obvioulsy I am busy sub-netting the network into smaller chunks.
I beleive setting port security etc would also help, but I would just like to be sure that this table blowing is in fact what is happening
Many thanks !
situwayne Tue, 04/03/2007 - 08:47
can you clarify....what type of traffic...is it broadcast?
"Occaisionally I will etherreal a switch port and see traffic between 2 hosts which we shouldn't see in a switched network."
paul-d Wed, 04/04/2007 - 01:20
hi,
No it is traffic between individual hosts suggesting the switch has blown its L2 table and is acting as a hub
cheers
nyr.hakeem-habeeb Wed, 04/04/2007 - 02:15
it could also be that the MACs have been aged out of CAM so the switch is in the process of re-learning the MACs.
Rgds
HH
bbaillie Wed, 04/04/2007 - 02:24
  • Bronze, 100 points or more
Try the command "show spanning-tree detail" and at line six of the VLAN in question, check to see how long its been since the last topology change (should be days or weeks not minutes). Likely you are seeing the results of topology changes caused by lack of "portfast" being enabled on the access ports. Or you have a link flapping somewhere in the network, causing the changes.
Cheers,
Brian
nz-ipv6 Wed, 04/04/2007 - 19:36
Hi Paul,
There are times in the network , when you will see unicast traffic on a port where it should not be.
This could happen because of:
a) Microsoft servers running NLB
b) Unicast flooding
I would recommend to read the articles that will help you to understand it better.
http://cisco.com/en/US/partner/products/hw/switches/ps700/products_tech_note09186a00801d0808.shtml
http://forums.microsoft.com/MSDN/ShowPost.aspx?PostID=1176827&SiteID=1
paul-d Thu, 04/05/2007 - 00:46
thanks I am aware of the load balancing issue and we put those into a seperate VLAN.
Sub netting the network should lessen and then eliminate the problem.
The question was what command can I issue on a switch to determine whether it has blown its L2 forwarding table.
nyr.hakeem-habeeb Thu, 04/05/2007 - 04:06
The sh mac-address-table count should show you the number of available MAC space available on the switch (see sample output below)
Mac Entries for Vlan 1:
Dynamic Address Count : 0
Static Address Count : 0
Total Mac Addresses : 0
Mac Entries for Vlan 100:
Mac Entries for Vlan 101:
Total Mac Address Space Available: 7453
