PIX Nat/Pat issue
Answered Question
Apr 3rd, 2007
I have a global pat for a clients subnet to access the internet and a static nat for a specific host to host connection accross a site to site vpn. I recently added another static nat w/ access list and now the host can't access the internet. The client hits the static access-lists but it never hits the global pat for the internet. I have a pix 525 running 6.3.3 Any thoughts as to why this is happening? I cant reproduce this effect in the lab.
Correct Answer by David White about 10 years 3 weeks ago
Ah yes. You bring back good memories doug :-)
You are running into bug CSCec63822. It was resolved in 6.3(3.136) and later. There is no workaround other than upgrading.
Sincerely,
David.
PS> Please don't foget to mork the issue resolved if it solves your problem so we can check this issue off the list.
Overall Rating: 5 (1 ratings)
abinjola Tue, 04/03/2007 - 08:51
  • Cisco Employee,
can you post the config and the ip address of client in Question..?
DOUG KIRK Tue, 04/03/2007 - 09:05
User 100.5.7.47 hits staic site to site access-lists but now won't hit Global PAT
Global PAT for Internet
global (outside) 10 192.252.127.254
nat (inside) 10 100.5.7.0 255.255.255.0 0 0
Site to Site #1
access-list host-to-host1 permit ip host 100.5.7.47 host 100.79.104.187
static (inside,outside) 192.252.127.241 access-list host-to-host1 0 0
Site to Site #2
access-list host-to-host2 permit ip host 100.5.7.47 host 100.200.251.110
static (inside,outside) 206.112.159.32 access-list host-to-host2 0 0
Correct Answer
David White Tue, 04/03/2007 - 19:48
  • Cisco Employee,
Sincerely,
David.
DOUG KIRK Wed, 04/04/2007 - 04:53
Thanks for the info. I have found a workaround until we can upgrade code.
I created a new policy NAT for this specific host.
access-list host-pat deny ip host 100.5.7.47 host
x.x.x.x
access-list host-pat deny ip host 100.5.7.47 host y.y.y.y
access-list host-pat permit ip host 100.5.7.47 0.0.0.0 0.0.0.0
nat (inside) 10 access-list host-pat 0 0
This took care of my problem for the time being. We are scheduling a time to upgrade code.
Thanks for your help.
David White Wed, 04/04/2007 - 06:06
  • Cisco Employee,
Hi Doug,
Be careful with the workaround, as 'deny' statements are not supported in policy-nat. So, your results may be unpredictable.
But, at least it is working for the time being :-)
David.
