Frame relay Lab
Answered Question
I need some help with a home training lab.
I have a 1720 router with 2 56k csudsu wic cards and have a 2507 router with 16 port hub, I need to know if I can setup frame relay from the 56k wic cards to my 2507 router and if possible the steps needed to make it work. I have checked the internet and tried everything I could find with nothing working. Thanks for any help to make this work.
Steve Sisson
Correct Answer by m-haddad about 9 years 11 months ago
You don't need a T1 WIC. In working environment the client has a Router with physical interface terminated to the CSU/DSU. This CSU/DSU will provide L2 connectivity to the frame-relay WAN.
As I mentioned before you should be able to simulated a back to back frame-relay test lab.
Hope this helps,
Overall Rating: 4 (2 ratings)
m-haddad Tue, 04/03/2007 - 11:49
You can only run back to back frame-relay connection. You can connect both routers to the CSU/DSU and then connect the CSU/DSU together.
As I said it is only frame-relay back to back.
Let me know if this helps,
Appreciate your rating,
Correct Answer
m-haddad Wed, 04/04/2007 - 13:28
Hope this helps,
