I'm pulling my hair out lol......
Apr 3rd, 2007
First off thanks everyone so much for all your help. I've managed
to get the VPN Connections going and can connect to my PIX/VPN
just fine....
I for the life of me CANNOT seem to get anyone's drives to map or
even see the "Network Neigborhood" I just see my own network.
Does anyone know why? I've read some things about LMHOSTS
and WINS and the clients are getting a WINS server under the group
but still no go..... :/
It's driving me batty!
So basically
Home VPN Client<----->VPN/PIX<-----Internal exchange mailserver
haroon.shaikh Tue, 04/03/2007 - 13:09
Greetings Mate,
Are you able to ping to end hosts?
- If your cant ping, check your VPN
- If ping succeedsd, then you might have to enable NetBIOS over the VPN.
ixholla69 Tue, 04/03/2007 - 13:24
What's the way you can enable netbios over vpn? Just so I can check that...
haroon.shaikh Tue, 04/03/2007 - 13:37
What type of VPN are you using?
Also, can you tell me what is your VPN server (PIX, ASA or Windows Server???)
haroon.shaikh Tue, 04/03/2007 - 14:08
Yes, that's your VPN sever.
What 'TYPE' of VPN connection are you using?
L2TP over IPSEC?
Which one?
ixholla69 Tue, 04/03/2007 - 14:19
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto dynamic-map outside_dyn_map_1 20 set transform-set ESP-3DES-MD5
crypto dynamic-map outside_dyn_map_2 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map_2 20 set transform-set ESP-3DES-MD5
crypto map outside_map 20 ipsec-isakmp
crypto map outside_map 20 match address outside_cryptomap_20
crypto map outside_map 20 set peer xx.xx.xx.xx
crypto map outside_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map_2
crypto map outside_map client authentication RADIUS
crypto map outside_map interface outside isakmp enable outside
