VLAN ACL Counters not Incementing
vblaha
All,
Weird issue when we apply an ACL to a VLAN interface we are noticing that the counters are not incrementing correctly or are taking some time ot increment. (Example line with known constant traffic is not incrementing but check it an hour later and the counters have incremented but not as much as expeceted. We are seeing this accross multiple platforms and ACL.
m-haddad
Level 5
Level 5
Did you try:
ip access-list update-threshold 1
ip access-list update-interval 1
THe above will update every hit.
Let me know if this solves your issue,
5 Replies 5
m-haddad
Level 5
Level 5
Did you try:
WOrked great thanks
Glad could help! :-)
Thanks for the rate,
I have the same problem, but the above commands are not availible on my Cisco 3750G running 122-25.SEE2. What's going on?
sorry there was missing part in the commands. The commands are:
ip access-list logging interval
ip access-list log-update threshold
Let me know if this answers your question,
