SSH v2 and a 2650
Apr 3rd, 2007
Hi, I was wondering if anyone can tell me whether the 2650 will support ssh v2. Currently running c2600-jk9s-mz.123-22.bin with 32MB Flash and 128MB RAM. I appreciate any input.
m.sir Tue, 04/03/2007 - 23:17
  • Gold, 750 points or more
Try to check Cisco feature navigator
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Select search by feature - like feature select Secure Shell SSH server Version 2 support click continue and like platform select your 2650 than you get list of IOSes with SSHv2 support
M.
Hope that helps rate if it does
mpipkin Wed, 04/04/2007 - 07:20
i have searched but the only results I get are for XM series routers. My 2650 is not an XM series. should I just try to load an image with the right feature set that my router meets the software requirements.
