IP QoS Class-Map doubt
Apr 3rd, 2007
Pre configuration:
class-map match-all COSP_TEST_1
match access-group name ACL_1A
match access-group name ACL_1B
class-map match-any COSP_TEST_2
match access-group name ACL_2A
match access-group name ACL_2B
Question:
1. Which is the optimized class-map configuration mentioned below?
2. Are both the configuration mention below are 'same'? i.e. will result to exactly same classification?
1. grouped in class-map and access-group:
class-map match-any COSQ_TEST
match class-map COSP_TEST_1
2. grouped in 2 class-map:
match class-map COSP_TEST_2
Overall Rating: 4 (1 ratings)
Brandon Buffin Tue, 04/03/2007 - 13:04
  • Purple, 4500 points or more
These will result in the same classification. Example 2 would be the most efficient as far as number of commands.
Hope this helps. If so, please rate the post.
Brandon
