VPN Client 4.04
Apr 3rd, 2007
I have internet access, I have the right username and password, and I have added ports to the windows firewall both UDP and TCP/IP info and still I get Reason 403:Unable to contact security gateway.
haroon.shaikh Tue, 04/03/2007 - 14:03
Greetings Mate,
First of all it looks like you dont have proper connectivity to your VPN server.
Check the following steps:
- Check your Internet Connectivity
- Check connectivity to remote VPN server (use ping)
- Can you resolve the DNS for VPN server.
- Disable all Firewalls
Also, Can you give some more details like what Operating System you are using, what is your VPN server (Is it PIX or ASA?)
PLEASE RATE THIS POST, IF YOU FIND IT HELPFUL
