Ciscoworks can it do Port mapping on 6000 switch?
Apr 3rd, 2007
Can ciscoworks map ports on a switch, or do anything like that?
Is there an easy way to map devices on a switch with 96 or more ports?
Joe Clarke Tue, 04/03/2007 - 20:38
What do you mean by map? CiscoWorks LAN Management Solution has the ability to display a graphical representation of a switch showing all ports (CiscoView). This tool allows one to change port attributes like speed, duplex, VLAN, etc. There are also more large-scale tools to do port-based configuration across many ports at once.
LMS also offers a layer 2 topology map which shows a CDP/ILMI based view of the network. From that map you can drill into a switch, and bring up the same CiscoView display. You can also do VLAN port assignments on a large number of ports from this same mapping tool.
richmorrow624 Wed, 04/04/2007 - 05:10
What I mean by map as in a switchport mapper.
Map hardware addresses to IP Addresses.
So you can document what device is on which port easily.
Can this be done in CiscoWorks?
Joe Clarke Wed, 04/04/2007 - 07:43
Absolutely. This is the main function of the User Tracking application within CiscoWorks Campus Manager.
