LAN-to-LAN VPN tunnel between PIX 515E & ASA5510
Apr 3rd, 2007
We need to connect a remote office which is in another country to our Headoffice in another country. We want to create a tunnel between this two firewalls to allow for the LAN in the remote office to connect to the LAN at the Headoffice.
We dont seem to be getting the tunnel up. Is creating a tunnel between 515E & ASA5510 acceptable? The network on the remote office is and the network at the headoffice is,,, Could someone help please?
Jon Marshall Fri, 04/06/2007 - 11:52
This should be perfectly possible. Attached are two links
1) Pix v6.x Lan-to-Lan setup
2) Pix v7.0 / ASA v7.0 Lan-to-Lan setup
Have a read of them and if you still can't get it working please post your current configs so we can help you further.
Danilo Dy Sat, 04/07/2007 - 02:11
If PIX or ASA IPSEC S2S VPN works with Juniper and CheckPoint, S2S VPN between PIX and ASA should work!
Can you post your config and the OS Version for both firewall?
