ipsec tunnel
Apr 3rd, 2007
Pls see my PIX version and the Hardware details below:
Cisco PIX Firewall Version 6.3(5)
Hardware: PIX-525, 256 MB RAM, CPU Pentium III 600 MHz
Flash E28F128J3 @ 0x300, 16MB
I added a host on the IPsec tunnel, run the following command:
FW# sh crypto ipsec sa | be HTX0062-NAT
local ident (addr/mask/prot/port): (HTX0062-NAT/
remote ident (addr/mask/prot/port): (
current_peer: CERNER-NAT:0
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.:, remote crypto endpt.: CERNER-NAT
path mtu 1500, ipsec overhead 0, media mtu 1500
current outbound spi: 0
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
But, the remote end was unable to initiate a connection.
My senior colleage said I have to reset the tunnel to get it working. I just want to know whether IT IS RIGHT or NOT.
Kelvin Cheung
Overall Rating: 5 (1 ratings)
jeremyarcher Wed, 04/04/2007 - 18:24
Yes, often you'll have to reset the tunnel if you change the crypto map.
cheungkfk Mon, 04/16/2007 - 15:26
I can't see my last post so I post it again.
I added a host on the existing ACL for the crypto map.
It did NOT work. Do I need to reset the IPsec tunnel?
Kelvin Cheung
cheungkfk Tue, 04/17/2007 - 18:21
Dear Jay Mia
First of all, thanks for your reply.
The command "clear isakmp sa" and "clear ipsec sa" will NOT delete any PIX configurations???
Kelvin Cheung
