(NM-1E = Description 1-port Ethernet Network Module) for Cisco 2600 Router
anupk
Can any one suggest me whether NM-1E = Description 1-port Ethernet Network Module) support in cisco 2600 router.
6 Replies 6
spremkumar
Level 9
Level 9
Thanks for your reply.
But there it mentioned cisco 3600 series not mentioned any where 2600.
Do 2600 support additional ethernet interface.
Anup
Hi Anup
you can make use of the below tool to find out whether your router model supports the required hardware and also the software required to have in the box..
http://tools.cisco.com/Support/Fusion/FusionHome.do
regds
Dear Prem
Is this link protected? i cannot access this tool.
Anup
desai.jaideep
Level 5
Level 5
It should support NM-1E.
But wont support any Ethernet with WIC slots(NM-1E2W etc)
JD
205590346
Yes it does, for sure.
Klean
