ADSL on cisco 2600
Apr 3rd, 2007
I have cisco 2600 router which already has 512 MB leased line connectivity. I would like to add an additional adsl line. can any one suggest me the possibility?
Amit Singh Tue, 04/03/2007 - 22:29
  • Cisco Employee,
Anup,
You can use ADSL's WIC on the 2600 router. You have to check the WIC slot avaialbility on your router.
WIC-1ADSL-I-DG 1-Port ADSLoISDN WAN Interface Card
WIC-1ADSL 1-port ADSL WAN Interface Card
WIC-1SHDSL 1-Port G.SHDSL WIC
WIC-1SHDSL-V2 1-Port two or four wire G.SHDSL WIC
WIC-1ADSL-DG 1-Port ADSL WAN Interface Card with Dying gasp
Please see the link below for WIC info
http://www.cisco.com/en/US/products/hw/routers/ps259/products_relevant_interfaces_and_modules.html
-amit singh
anupk Tue, 04/03/2007 - 23:29
Dear Amit
ADSL WIC required IOS higher than v 12. which i cannot upgrade since my router does not have enough memory /flash.
now i am planning to install NM-1E - 1 port ethernet network module and connect ADSL line into it.
Can you tell me whether this card support 2600 router and how adsl can be configured.
Thanks, Anup
