CSC-SSM module
Apr 4th, 2007
I've a problem on an ASA5510 with a CSC-SSM module (trendMicro). If there is http-Scanning enabled then internet radio doen't work. I worked out that if real-stream is enabled then it works fine. But if there is windows media streaming enabled then it doesn't work. Has anybody a solution for this prolem?
thanks
a-vazquez Tue, 04/10/2007 - 06:11
  • Silver, 250 points or more
Following steps may resolve your problem:
1. Login to ASA
2. Login to session 1
3. Select Troubleshooting Tools | Enable Root Account
4. Logout and Login again to session 1 but this time using the "root" account
5. Go to /opt/trend/isvw
6. cp intscan.ini intscan.ini.orig
7. vi intscan.ini
8. Look for the string "client_skip_content=". You should able to find the section, like the lines below:
server_skip_content=
client_skip_content_sp=
server_skip_content_sp=
9. Remarked out "client_skip_content=" with a "#" at the front.
10. At the top of "server_skip_content", add this line:
client_skip_content=User-Agent: RealPlayer,User-Agent: NSPlayer,User-Agent:
Windows-Media-Player
11. Save the file.
12. Logout and Login to session 1. Use the default account which is "cisco" to login.
13. Go to Service Status then restart all daemons.
