How to deploy multiple VPN gateways on WLC VPN Passthrough
Apr 4th, 2007
Hi all,
I got several VPN gateways(servers) behind my WLC 4402. I need configure their IP addresses in WLAN Layer3 security section VPN passthrough. But WLC permit to enter only one IP address of VPN gateway. What to do?
Thanks for your answers
Overall Rating: 5 (1 ratings)
drolemc Tue, 04/10/2007 - 09:09
  • Silver, 250 points or more
In WLC, you can configure only one VPN passthrough Gateway address. Multiple addresses cannot be configured
Dmitry Halavin Fri, 04/13/2007 - 06:09
What I've seen done in the past is configuring the WLAN for OPEN access, but then applying an ACL on the interface that only allows traffic to/from the VPN gateway(s). This may work for your needs.
kestutismeskonis Sat, 04/14/2007 - 06:28
Thanks for your advice.
Which protocols should i permit in ACL?
Is IP50,IP51 and UDP500 is enoughf?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
