Cisco CSS 11501 Service Redirection
Apr 4th, 2007
We have kept CSS 1 & CSS 2 in DMZ zone & servers are kept at LAN segment. Proxy, DNS & OID (Oracle Instance ID) services are created at these CSS. I want users coming from outside will hit CSS at DMZ zone & based upon access requirement he will be redirected to the LAN servers for proxy , dns or OID access. Whether it is possible? If so then please guide me with the config...
diro Thu, 04/05/2007 - 05:20
  • Bronze, 100 points or more
hello,
Took a quick look at the diagram:
Almost everything is possible with a css:
- But the servers should never be directly connected to the css.
- The CSS is a loadbalancer so having 1 proxy and 1 dns on 1 css has no use
- What you first should do is draw the flows which you want to have
- You should decide what type of redundancy that you want: box2box / vip redundancy
Good luck
Dimitri
