6509E and Sup720
Apr 4th, 2007
Can you tell me what if any slots I have to place the following part numbers on either a 6509E or 6506E?
WS-SUP720-3B Sup 720 Engine
WS-6704-10GE 4 port 10GE
WS-X6768-GE-TX Fabric Enabled Line card
Help rated!
Overall Rating: 5 (3 ratings)
Jon Marshall Wed, 04/04/2007 - 01:45
Hi Gavin
Primary supervisor goes into slot 5. Secondary supervisor (if you have one ) goes in slot 6.
The other blades can go in any other slots. Only on the 6513 chassis do you have to be careful where you place blades.
ankbhasi Wed, 04/04/2007 - 03:53
Hi Jon,
Just a small correction that the concept of primary and secondary supervisor will only when you have both the supervisors at a same time in chassis.
But if you have just one supervisor you can insert directly into any slot let it be 5 or 6.
So single sup can work fine in slot 6 also.
