04-04-2007 05:47 AM - edited 03-03-2019 04:25 PM
I know it's for the 1700 series but would the 1ENET WIC work in my 2620? I really need something with an rj54 connection that can be configured to work between my cable modem and my network.
04-04-2007 08:11 PM
Hi John
As per the CCO document Cisco 2600 supports NM-1E module by default.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_relevant_interfaces_and_modules.html
Also Cisco 2620 platform comes up with 1 network module slot platform it can accomodate NM-1E module..
http://www.cisco.com/en/US/products/hw/routers/ps259/ps265/index.html
regds
04-08-2007 06:01 AM
the WIC-1ENET is not supported on the 2600 router>Refer here for the compatability matrix -
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a00800ae37f.shtml
You 2620 has 2 ethernet ports, so you could use on to connect to the cable modem and the other would be your inside network.
