Access denied
Apr 4th, 2007
Hi there,
there is two servers one is on VLAN10 and another on VLAN20.
User needs the access between these server on port 80. I tried to telnet on port 80 from to these servers from its respective VLAN which was successfull. But from the server its blocking. I have checked the ACLs there is no such thing to block. the ACL is like this
permit tcp any any reflect tcptraffic.
Can some shen a light on this at the earliest
Thanks in Adv
cisconoval Wed, 04/04/2007 - 06:19
can some one help me please...its very urgent..
If I have missed out any information please let me know
royalblues Wed, 04/04/2007 - 06:22
On which side of the switch is this access-list applied?
Narayan
royalblues Wed, 04/04/2007 - 06:33
Can you try to add the access-list on the other vlan too and check
Narayan
cisconoval Wed, 04/04/2007 - 07:43
I hope its not required because from Vlan10 to server I can telnet but from server on VLan10 only its not happening...!!!
Why it is happening like this what would be the root cause please...
cisconoval Wed, 04/04/2007 - 08:47
Is any more suggesstion please.
Did ping and tracert from Server A(VLAN10) to Server B (VLAN20) which was successfull..
cisconoval Wed, 04/04/2007 - 08:55
I hope the secinario is confused for you...
Just to recall..
I can telnet from switch (Vlan interface to server) but not from particular server..
more over the ACL is
avmabe Wed, 04/04/2007 - 08:59
Ok then... post switch config and servers ip configuration and mask/gateway information
cisconoval Thu, 04/05/2007 - 00:22
Can you please guide me the troubleshooting steps..as its policy violation I cant post the config details more over its Distribution layer switch....so masking the sensitive info is bit tough...
please
